1992 Buick Skylark High idle, hot or cold
1992 BUICK SKYLARK
112,000 MILES • 6 CYL • FWD • AUTOMATIC
CJC92
My daughter just bought this 92 Skylark. 3.3L V6 Auto. Check Engine light was on. Codes showed O2 sensor and TPS.
Both replaced and tested. Check Engine light is now out, and codes are clear but the car idles at 2000 rpm! Starts and runs great otherwise.
Pulled battery connections for 1 hour hoping to 'reset' the brain, no change.
Any ideas what to check next?
Jan 21, 2008 at 10:25 PM
LEGITIMATE007
  • 5,121 POSTS
make sure that all of your vacuum lines are hooked up or make sure they don't have any cracks in them. this will cause a very high idol.
let me know what happens.
Jan 26, 2008 at 10:41 AM
NAVYFRED
[quote:dfecdad342="cjc92"]Computer problem
1992 Buick Skylark 6 cyl Front Wheel Drive Automatic 112000 miles
Any ideas what to check next?[/quote:dfecdad342]
Did you fix the problem? If so, what did you do to fix it? I have the same problem. ([email protected])
Thanks.
Feb 8, 2008 at 9:32 PM
