1990 Buick Skylark starting
1990 BUICK SKYLARK
FIREHOTAARON
Engine Mechanical problem
1990 Buick Skylark 6 cyl All Wheel Drive Automatic
my buick want fire off it trys to crank but want i bought a coil pack and coil moduel but it still want fire but it trys to crank can u help me
Mar 8, 2009 at 2:14 PM
JDL
  • 16,098 POSTS
Hello, are there any codes? Your obd1, you can check codes yourself.
If it crank good but won't start, have a helper crank it, while you check for spark at the plugs and injector pulse. How's the fuel pressure?
Mar 8, 2009 at 2:21 PM
FIREHOTAARON
it gets good pressure no spark at coil pack
Mar 8, 2009 at 2:32 PM
JDL
  • 16,098 POSTS
If you have an injector pulse, that should tell you if there is an rpm signal, I can't tell you the crank sensor is faulty without checking the circuits. Do you have B+ and ground at the ignition module?
Mar 9, 2009 at 9:19 AM
