Where to start for diagnosing engine oil blowing back through hose to and into breather filter. PCV valve seems to be functioning, and engine seems to be running fine. Also, compression test seems to check out within specifications. The engine has an EGR valve and a four port "switching?" device. I have a vacuum tester and additional vacuum gauge, dwell meter, and multitester, but I don't have a functioning inductive timing light. Thank You.
Jul 21, 2009 at 4:33 AM
