1995 Buick Skyhawk water always on driver side on floor
1995 BUICK SKYHAWK
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
BARDEN
MEMBER
FOLLOW
there always dampness on driver side floor no sign window leak or sealant . please help
Apr 7, 2009 at 8:57 PM
BARDEN
MEMBER
[quote:53cd6646b4="barden"]Smells problem
1995 Buick Skyhawk 6 cyl Two Wheel Drive Automatic 100000 miles
there always dampness on driver side floor no sign window leak or sealant . please help[/quote:53cd6646b4]
Apr 7, 2009 at 9:10 PM
JAMES W.
CERTIFIED EXPERT
If you're in an area where you need heat, I would guess your heater core is leaking. If you're using the AC. the evaporator drain from the heater box is plugged. The evap. drain should be a rubber tube coming through the firewall under the hood either in the center or towards the passenger side.
