current draw
BUICK ROADMASTER
JIMMIHAWK
I have a 1993 Buick Roadmaster 120,000 miles with 5.7 engine.My battery was draining overnight with everything off,so I did an engine off all lights etc. off and got a 2.26 amp draw I started pulling fuses one at a time and observed that when I removed the fuse that has CLUST. printed on the fuse box cover (15 amp) I got a normal draw of 0.1 amp draw .I was under the impression the CLUST meant cluster yet when I took the car out at night with that fuse removed the cluster lights and guages still were operating???So what does that fuse CLUST. incorporate in the system? Thanks much.
Mar 27, 2007 at 2:36 PM
CSBRANDENBURG
I have been chasing a battery drain. The fused circuit I can find that i find pulling current is pulling 0.110 amps.
You said in you rpost that is normal. I have no idea. But if you are sure then I'll quit chasing my circuit looking for 100 milliamps.
[email protected]
Aug 3, 2007 at 10:43 AM
