My fuel pump will not turn on. I have done the following:
*replaced the fuel filter
*replaced the Fuel Pump Relay
*confirmed the fuse is good
*replaced the fuel pump
*confirmed the fuel pump/sender in tank harnes is good.
*confirmed there is electric to the purple wire at the connecter at the fuel tank.
*replaced thefuel pump/oil pressure switch.( the manual shows two wires to the switch; however, there is only one wire to my switch)
The battery is strong but when I turn on the ignition on there is no sound from the fuel pump and no fuel is being pumped. I have tried to prime the pump by turning on the ignition and jumping from the hot side of the battery to the red wire( fuel pump test connector)
Still nothing works. Any help would be much appreciated.
Jul 10, 2009 at 11:20 AM
