1995 Buick Roadmaster starts hit throttle cut off
1995 BUICK ROADMASTER
129,280 MILES • V8 • 2WD • AUTOMATIC
MR_TCWILLIAMS
recently i started my buick up and it hesiated and sputtered after doing this two or three times it finally started up and drove when i tried to repeat the problem it would start so i took it to a shop they replaced the fuel pump, screen and filter but to no avail. then they changed the mass air flow sensor, the mass air pressure sensor and checked the throttle sensor still everytime you hit the gas pedal it sputtered and cut off now he is saying it has low fuel pressure but he dont know how what do you all think
Nov 1, 2010 at 12:26 PM
Could be the injectors and fuel pressure regulator leaking causing the low pressure
Nov 1, 2010 at 12:47 PM
