1995 Buick Roadmaster Replacing brake light switch
1995 BUICK ROADMASTER
60,000 MILES • V8 • 2WD • AUTOMATIC
NCAPKEV
I removed the knee bolster and metal plates under the steering column on 1995 Buick Roadmaster to replace the brake light switch. I think I located it correctly at the end of brake pedal but I cannot get it to come out. Do you just pull straight backwards?? Looks like it will break if I do. It also have 2 electrical connections on the end. Thanks for your time, KG
Apr 11, 2009 at 7:40 PM
I believe there is a retainer on it that needs removed before it will come off. Have you checked for that?
Nov 6, 2009 at 8:23 AM
