Engine Mechanical problem
1995 Buick Roadmaster V8 Two Wheel Drive Automatic
basically i have to replace the distributor and rotor and the tension pulley. i see the distributor is tucked behind the harmonic balancer and looks like the water pump, do i have to remove the water pump or how would i go about this ? if you could help it would be great!
Ryan
Ryan
Jun 25, 2009 at 11:23 PM
