1994 Buick Roadmaster IGNITION
1994 BUICK ROADMASTER
87,000 MILES • V8 • 2WD • AUTOMATIC
RENNIE
IS CONDITION;
ENGINE WILL NOT TURN OVER AFTER SUBJECTED TO A HIGH MOISTURE ENVIROMENT, IE CAR WASH OR PARKED IN RAINING CONDITION.
AFTER 25-30 STARTER CRANKS, ENGINE TURNS OVER.
CONDITION WILL NOT DUPLICATE UNTIL VEHICLE SUBJECTED TO IGNITION OFF/HIGH MOISTURE.
THANK YOU FOR YOUR CONSIDERATION.
RENNIE
Feb 21, 2008 at 5:32 PM
MASTERTECHTIM
  • 4,750 POSTS
the first place i would look is the starter motor. while cranking check the purple wire at the starter for power. if there is power then the starter is bad.
Feb 21, 2008 at 5:34 PM
RENNIE
FURTHER TROUBLE SHOOTING REVEALED THAT THE PRIMARY COIL WIRE LEAD AND THE COIL LEAD CONNECTOR WERE SEVERELY CORRODED.
REMOVED CORROSION AND RESIDUAL MOISTURE USING SCOTCH BRITE AND WD-40.
REASSEMBLED AND SPRAYED COIL AREA WITH WATER. PROCEEDED TO FIRE UP THE ENGINE.
NO RUNS, NO LEAKS, NO ERRORS. :mrgreen:
THANKS FOR THE TS SUGGESTIONS.
Feb 22, 2008 at 7:33 PM
