1993 Buick Roadmaster starter
1993 BUICK ROADMASTER
SIMPLYSAID73
Engine Mechanical problem
1993 Buick Roadmaster V8 Automatic 100000 miles
How do i know if the starter is out, and if it is how do i change it?
Feb 20, 2008 at 6:48 PM
Hi:
You will need to check to see if the starter is getting power. Have a helper turn the key to the start position while you check for power at the small wire on the starter. If there is power, replace it. Just disconnect the battery, remove the wires to the starter, and the two bolts holding the starter to the trans bell housing. Reverse the order to replace.
Nov 17, 2008 at 11:35 AM
