1992 Buick Roadmaster my break lights dont work
1992 BUICK ROADMASTER
CORTES018
Electrical problem
1992 Buick Roadmaster V8 Two Wheel Drive Automatic
Usually the high-mount brake lite is not wired through the turn signal switch. The lower brake lites are. You might check the brake lite switch, orange wire hot all the time, yellow wire is for high-mount brake lite, white wire goes to turn signal switch, all those wires should be hot when you step on the brake. what should i do after i complet this steps and i dont get a respones from a cable tanks
Feb 20, 2009 at 11:58 PM
BLUELIGHTNIN6
  • 16,542 POSTS
find out which component that wire is coming from. if the connections at that component are good and the fuse is good then whichever component the wire is from is faulty
Feb 21, 2009 at 12:03 AM
