1998 Buick Riviera turn over not starting
1998 BUICK RIVIERA
147,000 MILES • 6 CYL • 2WD • AUTOMATIC
JCOOLEY02
1998 Riviera turns over and wont start. Not fuel problem, just has no spark.
Replaced ignition control module, but still no spark. Was told it was a crankcase position sensor but havn't changed it yet, is this likely to be the problem?
Jan 4, 2009 at 10:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
Yes, a faulty crank position sensor could cause a no spark issue. Before purchasing and replacing parts, check the wiring of the sensor for shorts/open circuits and loose fittings. Also inspect all fuses and relays.
Hope this helps..
Thanks for using 2carpros.com!
Jan 4, 2009 at 11:48 PM
