1997 Buick Riviera removing positive battery terminal
1997 BUICK RIVIERA
130,000 MILES • 6 CYL • FWD • AUTOMATIC
BPOOLGUY1
Hi, I have dirty terminal on the positive side of the battery.For some reason i can't get the terminal off. is there any special tool that i need?
Feb 8, 2009 at 12:42 PM
BPOOLGUY1
[quote:e208330342="bpoolguy1"]Electrical problem
1997 Buick Riviera 6 cyl Front Wheel Drive Automatic 130000 miles
Hi, I have dirty terminal on the positive side of the battery.For some reason i can't get the terminal off. is there any special tool that i need?[/quote:e208330342]
Feb 8, 2009 at 12:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
No special tool is needed. Wedge your wrench underneath the battery terminal if the nut is too tight. Sometimes because of corrosion, the nut and bolt can become too tight or deteriorated to remove with the wrench. In this case, place the wrench under the terminal and "pop" up to release the grip.
Thanks for using 2CarPros.com!
Feb 8, 2009 at 1:32 PM
