1996 Buick Riviera My car will not start
1996 BUICK RIVIERA
16,700 MILES • 6 CYL • FWD • AUTOMATIC
FUNNYMAN21
Hi my name is Reggie and my buick riviera will not start. when i put the key in the ignition and turn it, it cranks but will not start what could the problem be.
Jul 11, 2008 at 6:00 PM
Do below and report back your findings
Do you have a check engine light On or flashing prior to this problem?
If the engine's condition is in tip top shape-do below to determine if its fuel or spark problem that's if its cranking over and refuses to start
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Jul 11, 2008 at 6:47 PM
