1996 Buick Riviera 4T60e
1996 BUICK RIVIERA
ALX2010
Transmission problem
1996 Buick Riviera 6 cyl Front Wheel Drive Automatic
Hi. My trany was broken. I changed converter,oil pump,forward piston &pin,all clutches,drum brakes,everything I need to change while rebuilding.Know what I have...When I put lever in D ,nothing happened.If I make acceleration to 1800 rpm something begin working & car begin to go.When I drive it, all gears work good,kikdown works too. After stop the situation is repited. The same thing with revers gear.What it can be ? Please,help. I am far from you. I am in Russia !
Please,my email is [email protected]
Oct 16, 2010 at 12:37 PM
HMAC300
  • 48,601 POSTS
youi really need to get a trans pro to look at this. but there is a pressure regulator in the trans ithat is electrically operated. It woul dbe beneficial to check alll your valves in the trans tosee if they work electrically or not....
Oct 19, 2010 at 6:33 PM
