1995 Buick Riviera heated seat switch
1995 BUICK RIVIERA
RAMON6701
Electrical problem
1995 Buick Riviera 6 cyl Front Wheel Drive Automatic
the heated seat will not turn off
Apr 5, 2008 at 5:36 AM
2CARPRO JACK
  • 11,533 POSTS
Could be a bad thermistor in the seat, not seeing it up to temp.My wiring diagram doesnt say what colors for what wires when it comes to that.Might need to find a shop that is capable of electrical diagnoosis to see if the thermistor is sending signal back to the controller (under drivers seat). In the mean time, you can disable it by removing the fuse (HTD ST) located in fuse center under the rear seat to keep it from possibly overheating and shorting out causing more damage
Apr 6, 2008 at 8:16 AM
