1995 Buick Riviera elcetircal computer pass key II
1995 BUICK RIVIERA
134,000 MILES • 6 CYL • 2WD • AUTOMATIC
J641350
  • 6 POSTS
engine will not crank or turn over was driving great when i replaced the brake line and jacked the car up in air to get under it security light is flashing about one second dont remember if it was doing it before or not cannot hear the fuel pump cross the starter under tha car it did turn over replace the fuel filter kiinda after thought cked the main wire from battery with light it is hot all fuses r good ? 3800 supercharger found one door sensor bad replaced it for alarm in car has antif theft device factory installed lbattery good condition i think it isnt reading the chip in the key for some reason and car battery didnt go down with a barake line change anit theft device should sound horn i assume did lock all doors set off alarm and rearmed it still not reaction from car tried the 10 minute leaving key in ignition trick no responce on that either suggestions
Oct 17, 2009 at 10:14 PM
KHLOW2008
  • 41,814 POSTS
Hi j641350, Thank you for the donation. Here are the basic diagnostics when engine can be cranked and not starting. Go through them and if you require additional assistance, just post replay and I will get back to you. NO START - ENGINE CRANKS OKAY (3.8L WITH C( 3 )I) NOTE: Before performing following tests, check battery condition, engine cranking speed and for adequate fuel in tank. General Inspection 1 . Ensure proper starting procedure is being used. Visually check vacuum hoses for splits, kinks and proper connections, as shown on Vehicle Emission Control Information label. Check ignition wires for cracking, hardness and proper connections at both coil pack and spark plugs. 2 . Remove spark plugs. Check and replace as necessary. In very cold temperatures, ensure oil is proper viscosity and not contaminated with gasoline. Ignition System (VIN K, L & 1) 1 . Ensure TP sensor scan is less than 2.5 volts. If not, see Code P0123 chart. Scan PASS -Key (R) II. Display should show ENABLED. If not, diagnose theft deterrent system. Check for stored trouble codes. If engine has not been started for at least 8 hours, MAT sensor scan temperature should be close to ECT sensor scan temperature. 2 . Disconnect tachometer wire (if equipped). A shorted tachometer or tachometer circuit will not allow vehicle to start. Disconnect cam sensor and attempt to start engine. If engine starts, see Code P0341 chart. If engine does not start, go to next step. 3 . Reconnect cam sensor connector. Compare scanned ECT sensor temperature with actual coolant temperature. If scanned value are not close, replace coolant sensor. Depress accelerator pedal about 25 percent throttle angle. Attempt to start engine. If engine does not start, go to next step. If engine starts, check IAC counts on scan tester. Check for blocked IAC passages. 4 . Disconnect all injector connectors and install injector test light on each injector harness connector. All lights should be off and should blink as engine is cranked. If any injector lights are on, go to step 8). If lights do not blink at all while cranking, go to step 9). If all lights are off and blink as engine is cranked, go to next step. 5 . Check for adequate spark using Spark Tester (ST- 125). Check for spark on plug wires No. 1, 3 and 5 (one at a time). Leave matching plug wire connected while checking for spark. If spark jumped across tester on all plug wires, check for fouled spark plugs or for fuel system as cause of no start. If spark did not jump tester or was not present on any plug wire, check poor ignition module connection or faulty ignition module. 6 . If spark did not jump tester on all plug wires, ensure spark plug wire resistance is less than 30,000 ohms. Ensure ignition coil secondary resistance is 5000 -6500 ohms at room temperature. Replace as necessary. If wires and coils are okay, remove coil that did not fire. Verify coil primary resistance of .5 - .9 ohm. Replace coil if necessary. If coil is okay, connect test light across ignition module terminals of problem coil. 7 . Crank engine. If test light flashes, check for poor coil -to-module connections. If connections are okay, replace faulty coil. If test light does not flash, replace ignition module. 8 . Turn ignition off. Disconnect PCM Red connector. Turn ignition on. If all lights are off now, replace PCM. If any lights are still on, repair short to ground in that injector drive circuit. 9 . Check ignition module power supply (F/P -IGN fuse and circuit). Repair as necessary. Disconnect fuel injector connector. Turn ignition on. With a test light connected to ground, check for battery voltage on Pink/Black wire of injector harness. If test light is on, go to next step. If test light is off, check INJ fuse. If fuse is blown, repair short to ground and replace fuse. If fuse is okay, check power supply to fuse and circuit between fuse and the injector harness connector. 10 . Turn ignition off. Disconnect ignition module connector. Turn ignition on. Install injector test light to any injector harness connector. Connect test light to battery voltage, and repeatedly touch terminal "D" of ignition module harness connector. See Fig. 3 . Injector test light should flash each time test light is touched to terminal "D". If injector test light flashes, go to step 12).
https://www.2carpros.com/forum/automotive_pictures/192750_ICMWiring95Riviera38Fig03_1.jpg
11 . If injector test light does not flash, check injector drive circuit between PCM and injector harness connector for open or short to voltage. Repair as necessary. If injector drive circuit is okay, check for open, short to ground or short to voltage on fuel control circuit No. 430 (Purple/White wire). If circuit is okay, problem is faulty connection at PCM fuel control terminal or faulty PCM. 12 . Turn ignition off. Using proper jumper adapter from Adaptor Kit(J- 35616), connect a fused jumper wire between ignition module harness connector terminal "N" and battery voltage. Connect a second jumper between ignition module harness connector terminals "M" and ground. Connect DVOM between ignition module harness connector terminal "H" and battery voltage. Observe voltmeter while cranking engine. Voltmeter should read about 1 -3 volts. 13 . If voltage is high, check circuit No. 646 for open or short to ground. If circuit No. 646 is okay, replace faulty crank sensor. If voltage is low, check circuit No. 646 for an open or short to voltage, circuit No. 645 for an open and circuit No. 644 for an open or short to ground. If all circuits are okay, replace faulty crank sensor. 14 . If voltage is about 1 -3 volts, move DVOM lead from terminal "H" to terminal "G". Crank engine and once again monitor voltage. Voltmeter should read about 5 - 7 volts. If voltage is correct, go to next step. If voltage is less than 5 - 7 volts, check for open or short to voltage in circuit No. 643. If voltage is greater than 5 - 7 volts, check for a short to ground on circuit No. 643. If no problem is found, crank sensor is faulty. 15 . If voltage is close to 5 -7 volts, turn ignition on. Probe ignition module harness connector terminals "P" with a DVOM connected to ground. If battery voltage is not present, repair open in ignition module power supply circuit. If battery voltage is present, problem is poor ignition module connections or faulty ignition module. Fuel System (VIN K & 1) 1 . Before checking fuel system for a no- start condition, check ignition for adequate spark. Check for proper fuel pump pressure and capacity. 2 . Turn ignition off. Install fuel pressure gauge. Using a fused jumper wire connected to battery voltage, jumper fuel pump test terminal. Turn ignition on. Listen for fuel pump operation and note fuel pressure gauge reading. 3 . If fuel pump operates and fuel pressure is okay, go to next step. If fuel pump does not operate, go to step 8). If fuel pump operates, but fuel pressure is not present, go to BASIC FUEL SYSTEM CHECKS. 4 . Remove jumper wire. Remove fuel pump relay. Connect test light between fuel pump relay connector Red wire and Black/White wire terminals. If test light illuminates, go to next step. If test light does not illuminate, connect test light between ground and relay connector Red wire terminal. If test light illuminates, check for open in Black/White wire. If test light does not illuminate, check for open in Orange, Pink or Red wire. 5 . Turn ignition off. Connect test light between relay connector Dark Green/White wire and Black/White wire. Turn ignition on. If test light illuminates for about 2 seconds, go to next step. If test light does not illuminate, check for poor relay connections. If connections are okay, replace fuel pump relay. 6 . Turn ignition off. Connect test light to ground. Backprobe PCM connector Dark Green/White terminal (fuel pump driver circuit). Turn ignition on. If test light illuminates for about 2 seconds, check for open in Dark Green/White wire. If test light does not illuminate, go to next step. 7 . Disconnect PCM connector. Using test light connected to battery voltage, probe PCM connector Dark Green/White wire terminal. If test light illuminates, check Dark Green/White wire for short to ground. If test light does not illuminate, check for faulty PCM connector or faulty PCM. 8 . Turn ignition off. Remove fuel pump relay. Using a fused jumper wire, jumper relay connector Gray wire and Red wire terminals. Turn ignition on. Fuel pressure gauge should indicate fuel pressure. If fuel pressure is present, check for poor relay connection, open in Red wire to fuel pump test terminal or faulty fuel pump relay. If fuel pressure is not present, go to next step. 9 . Turn ignition off. Raise and support vehicle. Disconnect fuel pump connector at fuel pump. Connect test light between fuel pump connector terminals. Turn ignition on. If test light illuminates, replace fuel pump. If test light does not illuminate, check for open in Gray or Black wire fuel pump.
Oct 17, 2009 at 11:28 PM
J641350
  • 6 POSTS
well replaced the pcm derm module cked the starter solenoid fuel pump main wire all ahve current fuel pump showin 44 pounds of fuel coming at it security light is still flashing even with total computer replacement tell me what u think it might be and how to fix this problem plz
Oct 19, 2009 at 7:39 PM
KHLOW2008
  • 41,814 POSTS
Here are additional test for you to check.
ENGINE CRANKS BUT DOES NOT START
1 . Turn ignition off. Disconnect PASS -Key II decoder module connector. Turn ignition on. Measure voltage between PASS -Key II decoder module harness connector terminal A3 and ground. If voltage is about 5 volts, go to step 3). If voltage is not about 5 volts, go to next step.
2 . Check Dark Blue wire for an open circuit or short to ground. Also check PCM connector C3, terminal D5 for good connection. If all circuits are okay, problem is with PCM.
3 . If voltage was about 5 volts in step 1), turn ignition off. Reconnect PASS -Key II decoder module connector. Turn ignition on. Backprobe PASS -Key II decoder module, measuring voltage between terminal A3 and ground. If about 2.5 volts are present, system is okay. If about 2.5 volts are not present, check PASS -Key II decoder module connector terminal A3 for good connection. If terminal contact is okay, replace decoder module.
© 2008 Mitchell Repair Information Co., LLC.
ENGINE DOES NOT CRANK OR START & SECURITY INDICATOR COMES ON & GOES OFF AFTER ABOUT 5 SECONDS
1 . Turn ignition off. Disconnect starter enable relay. Connect a fused jumper wire between starter enable relay harness connector terminals C1 and A2. Attempt to start vehicle. If engine cranks and starts, go to step 3). If engine does not crank or start, go to step 5). If engine cranks but does not start, go to next step.
2 . Check all power and ground circuits to PASS -Key II decoder module for an open circuit or short to ground. Check PASS -Key II decoder module terminals A1, A2, B2, B5, and B6 for good connections. If all wiring and terminal contacts are okay, replace PASS -Key II decoder module.
3 . If engine cranks and starts, measure voltage between starter enable relay harness connector terminal No. 85 (Purple wire) and ground while trying to start engine. If battery voltage is not present, check fuse 1A and Purple wire for an open circuit. If battery voltage is present, go to next step.
4 . Measure voltage between starter enable relay harness connector terminals C2 (Purple wire) and A1 (Yellow/Black wire) while trying to start engine. If battery voltage is present, replace starter enable relay. If battery voltage is not present, check Yellow/Black wire for an open circuit. Also check PASS -Key II decoder module terminal A4 (Yellow/Black wire) for good terminal contact. If wiring and terminal contact are okay, replace PASS -Key II decoder module.
5 . Ensure starting system is operating correctly. If starting system is okay, disconnect PCM Blue connector C3. Measure resistance between terminal E6 (Dark Green wire) and ground. If resistance is less than infinite, repair short to ground in Dark Green wire. If resistance is greater than infinite, starting system is at fault.
Oct 20, 2009 at 11:56 AM
J641350
  • 6 POSTS
tahnks for all the hlep decide to do it lol had it towed to the dealer will be fixed by them will let u know what was wrong with it when i can
Oct 20, 2009 at 9:07 PM
KHLOW2008
  • 41,814 POSTS
Too bad we were not able to assist in resolving the problem.
Any input would be greatly appreciated and the info would be of help to others who might encounter the problem.
Thank you for using 2carpros.
Oct 21, 2009 at 7:48 AM
J641350
  • 6 POSTS
yes took it to gm dealer and yep was the pass key ii system gineition of course they replace ignition swith as well as the blac pass key box lol 550 just to let u all know is what it cost me and u guys r great just so know u r most appreciated
Oct 22, 2009 at 8:48 PM
KHLOW2008
  • 41,814 POSTS
Good to know that you have solved the problem though it has dented your pocket. At 550, the damage is not too bad.
Thank you for the input and appreciation. You just made my day.
Have a great day.
Oct 23, 2009 at 7:32 AM
