My car will jerk or miss occasionally. Usually at highway speed. Some days it won't do it and sometimes it does it several times in 10 miles.
Jul 23, 2009 at 8:25 AM
BUDDYCRAIGG
CERTIFIED EXPERT
we need a little bit more info from you.
You need to be my eyes, ears, and body.
I'm fishing for details, like it will improve if you step on the gas peddle harder or less,
it does it only when it's hot
it only does it on days that end with "Y"
stuff like that.
Jul 23, 2009 at 7:34 PM
JAMINRC
MEMBER
It does it when it's hot, under load, like going up a slight incline. It does not do it under heavy acceleration. I have changed the plugs and I'm going to change the fuel filter.
Steve
Jul 24, 2009 at 7:40 AM
BUDDYCRAIGG
CERTIFIED EXPERT
Simulating a load in the garage is going to be hard to accomplish.
The first thing I would check is the fuel pressure.
and a compression test, just to rule them out.
after that we get to guess if it's an injector or ignition problem.
Jul 24, 2009 at 9:39 AM
JAMINRC
MEMBER
I will check pressure and compression, it may be a week or so before I get back to you.
Thanks, Steve
