Getting a EO41 trouble code. (Cam sensor failure) Already changed out the cam sensor and ignition module. Going by the flow chart from the manual for this error code tells me that my new ignition module is bad. Flow chart has me check cam sensor wiring harness at points A-B and B-C. A-B is low (5 volts), B-C is OK. Ohmed out circuit 633 OK from module to sensor and to ground. Any suggestions.
Thanks.
Thanks.
Feb 10, 2009 at 2:43 PM
