2006 Buick Rendezvous NO CODE FOUND
2006 BUICK RENDEZVOUS
64,000 MILES • 6 CYL • AWD • AUTOMATIC
BILLBERRY58
The AWD disable lights on it runs fine,drives alright but checked for codes at Auto Zone the test says no code found .
How do I get the light to go off ?
I can't donate at this time i've been out of work for over 9months please help .
Sep 14, 2009 at 10:33 AM
BRIAN 1
  • 1,030 POSTS
inspect connector C305 and C305B at the body pass through for corrosion, if no corrosion is found suspect the differential clutch pump actuator check valve as the possible cause.check this first.
Sep 14, 2009 at 6:53 PM
BILLBERRY58
There's no corosion differntail cluth pump actuator check valve good...now what should I look for ?
Sep 17, 2009 at 8:47 AM
BRIAN 1
  • 1,030 POSTS
how did you check the clutch pump actuator?did you test the circuit?did you find any bent terminals or corroded terminals at the pass throught at C305 that is located on the floor to the rear of the driver's seat?this is common on these.only other fix is a PCM,AWD gets its input from the PCM.before you start replacing unnecessary parts post back with what you tested,circuits,any data from a scan tool,etc.
Sep 17, 2009 at 5:16 PM
