2006 Buick Rendezvous moaning noise
2006 BUICK RENDEZVOUS
48,000 MILES • 6 CYL • AWD • AUTOMATIC
JOEDAMAINIAC
I have purhcased a 2006 Buick Rendevous.
When turning left or right there is a moaning noise coming from the front of the vehicle. I was told this noise was common due to being an all wheel drive vehicle. We had the fuild changed in the vehicle to stop this noise but did not work.
Is there a mechanical problem with the vehcile or do all Rendevous make a similar noise?
Oct 20, 2008 at 12:50 PM
DENNYP
  • 1,824 POSTS
Make sure the noise isn't coming from the rear end. There is an electrical connector on the rear end housing, disconnect it. Drive in circles to see if the noise is gone. If no more noise, flush the rear end fluid. If the noise is still there after that, replace the rear end pump assembly.
Oct 29, 2008 at 3:54 PM
