2004 Buick Rendezvous transmission fluid leak after flush
2004 BUICK RENDEZVOUS
160,000 MILES • 6 CYL • FWD • AUTOMATIC
KENTHURGOOD
  • 5 POSTS
Hi, My Rendezvous didn't have any leaks whatsover till I took it to my local garage and had the transmission fluid changed. Now there are pink spots under the front. Took it back to the garage and when they looked, they found the lower line leaking. I asked if this was due to the flush they did and they said `No'. I am suspicious to say the least at the coincidence. Should I go after a free repair bill this time? I'm not really much of a mechanic. Appreciate any input.
Dec 18, 2009 at 6:27 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
This may just be a loose connection, i would just ask then to re check the lines and report on this leak, if they did a flush, they more than likely have the cooler lines undone.
mark (mhpautos)
Dec 18, 2009 at 7:52 AM
