2003 Buick Rendezvous window stop working
2003 BUICK RENDEZVOUS
48,000 MILES • 6 CYL • 2WD • AUTOMATIC
WILLIAM K
my windiw on the driverside works sometimes and sometimes it get stuck either down or halve way.
Feb 27, 2009 at 2:52 PM
Hi:
This could either be a switch going bad or a loose connection to the motor. I would recommend removing the door panel and checking for loose connections. If nothing is found, check if the motor is still getting power when the window doesn't work. If it is, chances are the motor is going bad. If it isn't, start checking switches.
Apr 4, 2009 at 4:16 PM
