Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Buick
Rendezvous
Warning Lights
Service Light
2003 Buick Rendezvous service light on
2003 BUICK RENDEZVOUS
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
CSCOTT71
MEMBER
FOLLOW
yes i get it scaned and code po453 came up and i repaced pressure sensor in the tank and unhooked the battery and drove 20 miles and came back on
Jan 4, 2009 at 8:46 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
Check volts at wiring. Should not exceed 4.9 volts or it will illuminate the engine light with p0453 code.
Thanks for using 2carpros.com!
Jan 4, 2009 at 8:53 PM
CSCOTT71
MEMBER
[quote="bluelightnin6"]Check volts at wiring. Should not exceed 4.9 volts or it will illuminate the engine light with p0453 code.
but if to high how do i fix
Jan 4, 2009 at 9:02 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
If volts are too high, you will need to replace the connectors on the wiring, or the wiring itself.
Jan 4, 2009 at 9:04 PM
