Wheel Bearing/Hub Replacement - Front
Tools Required
J 28733-B Front Hub Spindle Remover
Removal Procedure
Raise and support the vehicle. Refer to Vehicle Lifting.
Remove the tire and wheel.
Disconnect the wheel speed sensor electrical connector.
Remove the wheel speed sensor electrical connector from the bracket.
Remove the wheel drive shaft nut.
Remove the brake rotor.
Install the J 28733-B to the wheel bearing/hub.
Use the J 28733-B in order to push the wheel drive shaft out of the wheel bearing/hub. Caution: These fasteners MUST be replaced with new fasteners anytime they become loose or are removed. Failure to replace these fasteners after they become loose or are removed may cause loss of vehicle control and personal injury.
Remove and discard the wheel bearing/hub bolts. Important: Ensure that the wheel drive shaft outer seal (boot) is not damaged.
Remove the wheel bearing/hub.
Installation Procedure
Install the wheel bearing/hub. Notice: Refer to Fastener Notice in Service Precautions.
Install NEW wheel bearing/hub bolts.
Tighten the new wheel bearing/hub bolts to 130 Nm (96 ft. lbs.).
Install the brake rotor.
Install the wheel drive shaft nut. Important: Ensure that the connector clip engages the bracket properly.
Install the wheel speed sensor electrical connect to the bracket.
Connect the wheel speed sensor electrical connector.
Install the tire and wheel.
Lower the vehicle.
Apr 6, 2009 at 7:35 PM
