Water Pump Replacement
Removal Procedure
Drain the cooling system until the coolant is below the level of the water pump. Refer to Draining and Filling Cooling System .
Remove the drive belt guard.
Loosen the water pump pulley bolts.
Remove the drive belt. Refer to DRIVE BELT REPLACEMENT .
Remove the water pump pulley bolts.
Remove the water pump pulley.
Remove the water pump bolts.
Remove the water pump.
Remove the water pump gasket.
Clean the water pump mating surfaces.
Installation Procedure
Install the water pump gasket.
Install the water pump.
NOTE:Refer to FASTENER NOTICE .
Install the water pump bolts.
Tighten
Tighten the bolts to 10 N.m (89 lb in).
Install the water pump pulley.
Install the water pump pulley bolts.
Install the drive belt. Tighten
Tighten the water pump pulley bolts to 25 N.m (18 lb in).
Install the drive belt guard.
Fill the cooling system. Refer to Draining and Filling Cooling System .
Dec 28, 2008 at 8:54 PM
