2002 Buick Rendezvous Steam escaped from radiator
2002 BUICK RENDEZVOUS
78,000 MILES • 6 CYL • 4WD • AUTOMATIC
GRAHAMLUCYREED
Went to check AC level onh car. Took off low level cap, put AC on full, turned engone on and a loud popping / hissing sound was heard under bonnet. Steam was escaping + small amount of green fluid....placed hand by radiator fan and felt gushing air. After circa 5mins it stopped gushing air...and there was very little fluid on the floor (less than a table spoon!!!!). Turned car back on, no gushing sound, no fluid escaping and the radiator fan kicked on to cool engine down!!! Took car out for drive around block and all seems OK. But concerned that raditor may have a leak!!! Any suggestions?
Aug 27, 2008 at 7:57 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
have a cooling system pressure test done, this will show up any external leaks, and don't forget to have the pressure cap tested as well.
Mark (mhpautos)
Aug 27, 2008 at 8:54 PM
GRAHAMLUCYREED
Having driven it circa 60 miles everything seems OK however I feel the AC is no longer powerful - just had $650 worth of work done on new AC...could that be the expulsion of air? p.s. have got it booked in end of the week for prssure check so tx for that one...
Aug 30, 2008 at 10:25 AM
MHPAUTOS
  • 31,937 POSTS
Hi there the A/C system will have no bearing on you cooling system problem at this level.
Mark (mhpautos)
Aug 30, 2008 at 5:58 PM
