2002 Buick Rendezvous slow start
2002 BUICK RENDEZVOUS
89,000 MILES • 6 CYL • AWD • AUTOMATIC
RXLONZO
new battery in truck... when I start it, it turns over slowly, then catches to start. It has happened about 6 months ago, a guy from AAA told me a battery cable was loose, but I checked and could not find the cable loose at all.
Oct 6, 2008 at 4:52 PM
JASONRAY
  • 213 POSTS
The starter could be drawing WAY too much amperage. This will cause it to spin slow and eventually, it won't start at all. It'll just click. To check this, you'll need access to an electrical system checking device. We have one at my shop. It connects to the battery and has an amp lead that clamps around the positive cable from the battery to the starter. If you are able to find this type of tester, the amps on a good starter should be about 175 to 225 amps. If it's approaching 300 or more, the starter is drawing too much amperage and needs to be replaced.
Oct 19, 2008 at 6:05 PM
