The driver window switch (AUTO) no longer operates normally to move the window up. Inserting a screwdriver under the switch and forcing it does move the window up. There seems to be poor contact, or the switch is worn.
Are the window switches in the master switch interchangeable? i.e. can I change a rear window switch with the driver window switch?
If I need to purchase a replacement master, what other GM models have a compatible master switch?
Thank you
Thank you
Apr 12, 2010 at 5:59 PM
