REMOVAL:
Drain the cooling system.
Remove or disconnect the following:
-Wiper module
-Brake booster vacuum hose
-Air cleaner cover and intake tube
-Throttle and cruise control cables, from the TBI bracket, also
-Transmission filler tube
-Hoses from the heater core
-Right and left instrument panel insulators
-Center floor air outlet
-Heater outlet duct
-Tie strap holding the instrument panel harness to the heater core cover
-Heater core cover
-Heater core retaining screw
-Heater core
INSTALLATION:
Install or connect the following:
-Heater core
-Heater core retaining screw. Torque to 8 inch lbs.
-Heater core cover. Torque to 8 inch lbs.
-Heater outlet duct. Torque to 8 inch lbs.
-Hoses to the heater core
-Wiper module
Hope this helps..
Thanks for using 2carpros.com!
Jan 4, 2009 at 8:23 PM
