2002 Buick Rendezvous FUEL PUMP REPLACED
2002 BUICK RENDEZVOUS
DBOWENS65
Engine Performance problem
2002 Buick Rendezvous 6 cyl Front Wheel Drive Automatic 145K miles
I JUST REPLACED THE FUEL PUMP... IT'S PUMPING GAS BUT THE VEHICLE WONT START UP (NOT GETTING TO THE ENGINE)
WHAT COULD BE CAUSING THIS PROBLEM?
Dec 21, 2009 at 2:54 PM
Check the fuel filter if it's clogged up and check the injectors if they are pulsing.
Dec 23, 2009 at 4:00 AM
DBOWENS65
THANK YOU FOR YOUR RESPONSE REGARDING MY 2002 BUICK RENDEVOUS... YOU INDICATED TO CHECK THE FUEL FILTER TO SEE IF ITS CLOGGED.. WE REPLACED THE FUEL FILTER ALREADY WITH A NEW ONE. YOU SAY CHECK THE INJECTORS.... FUEL INJECTORE?? WHERE ARE THESE LOCATED? SHOULD I ATTEMPT TO PUT DRY GAS IN THE TANK? I REALLY NEED MY VEHICLE. WITH THE HOLIDAYS , MONEY HAS BEEN TIGHT...
AGAIN...
THANK YOU !!
Dec 27, 2009 at 9:29 AM
