2002 Buick Rendezvous anti lock brake light on and AWD disa
2002 BUICK RENDEZVOUS
130,000 MILES • 6 CYL • AWD • AUTOMATIC
JAYJAY27
Jan 15, 2010 at 10:03 PM
BMRFIXIT
  • 19,053 POSTS
Have to scan for codes
ABS codes
most common and likely to be the problem is a wheel hub bearing and sensor assembly
codes should point you to it
good luck
Jan 15, 2010 at 10:06 PM
SUPERSTIK69
[quote:6d1b5375dd="JayJay27"]Brakes problem
2002 Buick Rendezvous 6 cyl All Wheel Drive Automatic 130000 miles
130000[/quote:6d1b5375dd] i had the same problem on one of those its the wheel baring,,if you have changed one side,,or if one of the wheel baring hubs is bad you have to change both sides or the awl drive will turn off,,,wheel barings are about 30mins to put on and 60 bucks a peace so make shur you know witch one is bad,
Jan 21, 2010 at 7:18 PM
