Anti-lock and AWD warnings lights on?
2002 BUICK RENDEZVOUS
120,000 MILES • 6 CYL • AWD • AUTOMATIC
ARDIE77
It seems when the car is driven about 1 mile from start point the Anti-lock brake light and the AWD disengage light luminate to notify driver of a problem. It is accurate because the rear wheels deliver no power when the light is luminated.
Oct 22, 2008 at 2:45 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It sounds that you have fault codes stored in both the anti-lock brake system and the transmission- transfer case in the all-wheel dive system. This will cause the poor performance you are experiencing. The best thing for you to do is have a CAN scan- Controller Area Network performed to determine what fault codes are stored in your vehicle's computer. Here is a tutorial showing what is involved with a CAN scan:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Once you have this performed get back to us with the code numbers and we can then properly diagnose the issues your vehicle is having. Hope this helps and thanks for using 2CarPros.
Jul 31, 2021 at 7:59 PM
