Low Coolant Light
BUICK REGAL
TOM F.
my 2002 regal ls, coolant light is on steady. the special coolant that it comes with was mixed with a quart or two of regular antifreeze.I have flushed it out and put in recommended anti freeze and a thermostat but the light stays on. there is no sensor in the coolant overflow resevoir. it has 67,000 miles.on a v6 3.8 engine. It runs good and does't seem to use any or little coolant. I do not see any coolant in oil or oil in coolant. the mix is 50/50. what should i do?
Jul 15, 2007 at 10:57 PM
CLY
  • 308 POSTS
I would replace the low coolant level sensor.It is located in the radiator about 4 to 6 inchs down on the sameside as the radiator cap....
note:remove right headlamp to replace senor...Makes it alot easier....
Cly
Jul 17, 2007 at 4:36 PM
SERVICE WRITER
  • 9,123 POSTS
I'm with Cly on that. Either replace the sensor or live with the light and keep checking periodically.
Jul 19, 2007 at 3:32 PM
