serpentine belt diagram?
2003 BUICK REGAL
TRAPPIN69
does anyone have a diagram for the serpentine belt?
Apr 5, 2010 at 9:49 PM
DOCFIXIT
  • 18,828 POSTS
This guide will walk you through the repair with the diagrams for your car below. https://www.2carpros.com/articles/replace-serpentine-belt 3.8L
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_435.jpg
Apr 6, 2010 at 9:50 AM
JAEGERSTEIN
I need the routing diagrams for a 2003 Regal GS serpintine belts.
Nov 18, 2019 at 12:46 PM (Merged)
MHPAUTOS
  • 31,937 POSTS
Hi there, Belt information. Mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic_89.jpg
JAEGERSTEIN
Thanks! I removed it thinking that there was a diagram on the car...
WHITTLER
The serpentine belt is worn and needs replacing. Does it have a special tensioner that requires specific tools or is it adjustable at the alternator.
Also do you have a diagram of how it fits around
all the components. Are there other suggestions that would be helpful such as removing a splash cover from beneath the car.
Nov 18, 2019 at 12:47 PM (Merged)
ZACKMAN
  • 4,202 POSTS
Look at you VIN. Match the 8th digit with the diagram. They all use a tensioner. Splash removal is not necessary. The belt is removed from the top of the engine. VIN "1"
https://www.2carpros.com/forum/automotive_pictures/55316_3800vin1_2.jpg
VIN "K"
https://www.2carpros.com/forum/automotive_pictures/55316_3800vink_2.jpg
VIN "L"
https://www.2carpros.com/forum/automotive_pictures/55316_3800vinl_2.jpg
2CP-ARCHIVES
  • 4,540 POSTS
1998 Buick Regal mileage: 65,000. I am getting ready to replace the serpentine belt and need to know if replacing the automatic tensioner is advised. The belt is not that bad, but i thought it was about time. Thank you!
Nov 18, 2019 at 12:48 PM (Merged)
2CP-ARCHIVES
  • 4,540 POSTS
Yes, it is a good idea to replace the belt tensioner when you replace the belt. Over time, the spring inside gets weak and looses tension.
RALPH BUZ ALMOND
serpentine belt jumps off pulleys.
STEVE W.
  • 15,113 POSTS
You have one of three problems. One of the accessories the belt drives is out of alignment. One of them has failing bearings causing pulley wobble. Or more likely is that you have a bad belt tensioner assembly.
