2002 Buick Regal Windshield Wipers
2002 BUICK REGAL
42,000 MILES • 6 CYL • 2WD • AUTOMATIC
RCODY420
Just recently, the driver side windshield wiper traverses beyond the usual stopping point before reversing direction, even beyond the windshield a bit which is causing the wiper to stick for a sec. It seems to park properly when turned off, so I can't imagine why. I see nothing obviously wrong with the wiper arm or how the wiper blade is seated in it, and the bolt seems tight
Jun 8, 2010 at 11:04 AM
FACTORYJACK
  • 4,159 POSTS
Had there been any previous history of it being operated in freezing weather or snow? There is not much that can go wrong with it. If the pivot is firm, it is either part of the mechanical linkage has been bent(which is not common), or the wiper arm has slipped on its spline. You can try to loosen the nut and move the arm back a few splines, in some cases it calls for a puller, but you can usually firmly wiggle the base and get it to come loose. It is a tapered, splined stud that it fits to, the arm is the softest of the metals to keep repair costs down. This should not have an effect on park, since it is resting against a hard stop.
Jun 9, 2010 at 12:13 AM
