security light is on, why?
2002 BUICK REGAL
COCOBELL
Upon starting my car this morning my security light was on and will not go off. Any help or info would be greatly appreciated!
Jun 8, 2006 at 2:37 PM
MDDGAWOLAN
your chip on your key is not making contact clean it with some keyboard spray -same problem with my 1998 regal gs. Sometimes there are issues with the small wires that connect the key tumbler and the anti-theft module. This will cause the fuel pump to not run
Try performing a relearn first to see if it takes- See the guide below
https://www.2carpros.com/articles/how-to-reset-a-security-system
May 12, 2011 at 2:47 AM
GMTECH
  • 537 POSTS
DO you actually a little pellet in your key, separate key for your door?
Jan 30, 2013 at 9:02 PM
JMONEY399
My security light is on and my car wont start I have heard that it is my VANT in my car is that self repairable.
Nov 19, 2018 at 6:24 PM (Merged)
The only place that will have the proper equipment to test it is a dealer. If you need to get it started, turn the key to the run position for 10+ minutes. It should start after that.
