Can you please tell me exactly where the fuel filter is located? THANKS
Jul 6, 2010 at 5:52 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
Under vehicle, driver side, below seating area, front of fuel tank, mounted on chassis in fuel line here is a guide that will walk you through the service
The fuel filter is located under the car on the left side near the fuel tank here is a guide and diagrams below to help you get the filter changed out.
Cheers
May 23, 2019 at 6:37 PM
(Merged)
MELINDA.FATANI
MEMBER
1 POST
Engine Mechanical problem
1998 Buick Regal All Wheel Drive Automatic 93000 miles
Where is the fuel filter located and how can I check to see if it needs to be replaced?
(Merged)
CERTIFIED EXPERT
check near the fuel tank or along the fuel rail. Fuel filters should be replaced aprox every 30K. You can check fuel pump pressure before and after the filter to know if it is plugged.
