2001 Buick Regal EVAP Emissions code & fuel filter
2001 BUICK REGAL
ANIMALAKAWILL
Engine Performance problem
2001 Buick Regal 6 cyl Front Wheel Drive Automatic
2 part question
Does my 2001 Buick Regal have a fuel filter?
A month ago it showed an EVAP Emissions code {& the local Auto Parts store employee could not tell me what that meant specifically} in the last week it has started to intermittently hesitate. Would replacing the EVAP Canister Purge Solenoid Valve be a solution?
Thank you,
Will
Oct 11, 2009 at 2:18 PM
SERVICE WRITER
  • 9,123 POSTS
Yes the Regal does have a filter.
What is the code for the evap?
Oct 11, 2009 at 5:46 PM
ANIMALAKAWILL
Unfortunately I was not with my daughter when she had Autozone read the code. I will attempt to get it read again.
In the owners manual there is no mention of a fuel filter, so of course there's no timeframe to have it changed. With 60,000 miles on the car would you think the fuel filter could be the culprit?
The hesitation seems to be constant if I really try to accelerate hard, the card starts to misfire. If I accelerate more slowly it seems to move along fine & I am able to get to highway speed 60-70 mph.
So far I have change the airfilter {which was hardly dirty} & I removed & cleaned the EGR valve {again this was not really fouled}. I also put in a can of Seafoam injector cleaner & filled it with premium.
Oct 12, 2009 at 8:28 AM
SERVICE WRITER
  • 9,123 POSTS
I would check the fuel pressure before and then after the filter replacement regardless of the code.
https://www.2carpros.com/forum/automotive_pictures/30961_ff_5.jpg
Look along the frame rail on thr rear driver's side.
Oct 12, 2009 at 10:11 AM
