2001 Buick Regal brakes bleeding
2001 BUICK REGAL
112,000 MILES • 6 CYL • 2WD • AUTOMATIC
DEEBCHILLIN
how to bleed brake system after mastercylinder replacement
May 6, 2010 at 3:33 PM
TOOOMANYTOYS
  • 513 POSTS
The easiest way is to bench bleed the master cylinder. Push master cylinder piston in with screw drive and block both passages when relaesing. From there gravity bleed all wheels. Then regular pump bleed to finish.
May 6, 2010 at 3:46 PM
