2001 Buick Regal 2001 Buick Regal EGR valve repair
2001 BUICK REGAL
140,000 MILES • 6 CYL • FWD • AUTOMATIC
WPOTTER
The check engine light has come on in my Regal. I had an auto supply store check the code and it said it the EGR valve was stuck. I have had no other symptoms to make me think there was even something wrong with the car. There is no sputtering, hard start, hesitation that I have noticed as of yet. Since I live in an area that has emission control I need to get this fix (not to mention I don't want to pollute the air any more than I have too). Now for my questions.
1. Is it possible that this engine light is due to a faulty sensor?
2. Is it possible to clean or otherwise repair the EGR valve?
3. How difficult is this repair? Could I, as a reasonably mechanically inclined person, make the repair on my own?
4. Is there any place I can find a repair manual for replacing the EGR valve? I have already looked on www.eautorepair.com with little luck.
Any help would be great! Thanks
Mar 9, 2009 at 3:09 PM
MERLIN2021
  • 17,250 POSTS
If you can post the code it may help, TSB's are plentiful on emmission related problems, also where the wiring harness passes through the A/C accumulator, there is a bulliten about the wires chaffing there, check that area for any worn thru wiring.
https://www.2carpros.com/forum/automotive_pictures/62217_regal_1.jpg
Mar 9, 2009 at 4:34 PM
