2000 Buick Regal MAF sensor
2000 BUICK REGAL
86,000 MILES • 6 CYL • 2WD • AUTOMATIC
REB18
I need the removal and installation procedures for the Mass Air Flow Sensor on a 2000 Buick Regal LS, FI, VIN K. Thanks
Feb 28, 2010 at 10:41 PM
The MAF sensor on this engine is attached to the throttle body assembly.
REMOVAL PROCEDURE
1.Turn the ignition OFF.
2.Disconnect the MAF sensor electrical connector.
3.Remove the screws holding the MAF sensor to the throttle body.
4.Remove the MAF sensor from the throttle body.
INSTALLATION PROCEDURE
1.Carefully position the MAF sensor to the throttle
body. NOTE: Refer to Fastener Notice in Service Precautions.
2.Reinstall the screws holding the MAF sensor to the throttle body.
3.Connect the electrical connector.
Mar 1, 2010 at 7:51 PM
