1999 regal po481
1999 BUICK REGAL
WRENCHES
i have a regal with 117000 miles on it, and recently trouble code po481 came up. both fans seem to be running fine, what else should i look for?
Aug 22, 2007 at 8:52 PM
SERVICE WRITER
  • 9,123 POSTS
Since the fans are working, it sounds like an intermitant problem that may involve wiring, connector or componenet failure. A relay may be starting to stick but not all the time. I would pull the cooling fan relays (3 of them) and get a look at the terminals for any corrosion or similiar. And then check the connections at the pcm and the area behind the fuse box for any abnormalites. But before doing all that, I would clear the codes and drive it and see if the problem is still active.
Aug 26, 2007 at 6:19 AM
