iI am having problems with my my transmission jerking with in gear changes.. almost as if the motor mounts were bad... i have had those replaced.. did not fix the problem... then a bad solenoid cade read in the diagnostic... had that replaced .. did not fix the problem. when the car is cool it runs great but after 10-15 mins when it gets hot it gets worse.. hesitating between gears...
Apr 4, 2010 at 9:11 PM
