Hi CarolRients,
Thank you for the donation.
Possible causes are :
1. Bad cylinder head or gasket. Check the radiator for presence of oil in coolant. Check engine oil for presence of coolant, it would be milky in color.
2. Bad transmission fluid cooler. This would result in oil in radiator as well. Check transmisison fluids for presence of coolant, would be milky pink in color.
3. Someone mistakenly topped up with oil instead of coolant.
Oct 25, 2010 at 11:41 AM
