1999 Buick Regal dash/radio/climate module/ lights problem
1999 BUICK REGAL
157,000 MILES • 6 CYL • FWD • AUTOMATIC
DPQUINN2003
dash/radio/climate control lights go to the lowest dim settings when the headlights automatically go on at night. when the headlights turn off however. the dash/radio/control module lights work great and the dimmer control can work as normal. what can do to fix the lighting problem and whats causing it?
Feb 24, 2009 at 12:01 PM
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_99regalpanel_1.jpg
Try check the fuse panel for the panel dimming fuse. If the fuse is good, then your headlight switch is faulty.
Feb 28, 2009 at 12:42 AM
