Instrument panel illumination lights won't come on, such that I can't see the spedometer or tachometer at night. The odometer, stereo, HVAC lights are on, but seem to be very dim. Adjusting the dimmer on the headlight switch does nothing. When I remove the Panel Dimming fuse, they get brighter.
Any suggestions? could it be the headlight switch? Is that relatively easy to replace?
Thank you,
Thank you,
Oct 27, 2009 at 9:04 PM
