1999 Buick Regal A/C panel does not display information
1999 BUICK REGAL
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
HEMIGEEZER
A/C works very cold, but have to play with buttons for several minutes to get system to work. On the display screen nothing lights up. I think I may have a bad panel. There is a micro module on he fuse panel for A/C, could that be the problem?
May 13, 2009 at 5:57 PM
2CARPRO JACK
  • 11,533 POSTS
If playing with the buttons will make it work, It could very well be the controller likk you said.If it begins working that usually mean the feeds are there, but the buttons arent working properly
May 17, 2009 at 11:48 AM
HEMIGEEZER
[quote:54f1ace84d="2CarPro Jack"]If playing with the buttons will make it work, It could very well be the controller likk you said.If it begins working that usually mean the feeds are there, but the buttons arent working properly[/quote:54f1ace84d]
Is the little module relay in the fuse box a plug in relay? Also is it a difficult job to change the control panel.
May 17, 2009 at 4:15 PM
2CARPRO JACK
  • 11,533 POSTS
Changing the control head shouldnt be too difficult.Exactly which Regal is this so I can look it up?
May 18, 2009 at 7:36 AM
HEMIGEEZER
Its a 1999 Buick Regal, 3.8 Supercharged 4 door VIN 2G4WF5215X1465797
May 18, 2009 at 8:05 AM
