1998 Buick Regal obd code reads p0453
1998 BUICK REGAL
CHESTERNUTS
1998 Buick Regal 6 cyl Front Wheel Drive Automatic
I recieve this code when I checked my obd system. The code tells me it's a Evaporative emmissions contol system pressure sensor high voltage. I have already replaced the MAF, and front O2 sensor. Is this code telling me the O2 after the resinator is defective?
Oct 23, 2009 at 9:10 AM
DOCFIXIT
  • 18,828 POSTS
P0453 Fuel Tank Pressure Sensor High Voltage possible causes bad ground, faulty sensor, or faulty PCM. Does car run O.K.? sensor in tank
Oct 23, 2009 at 10:13 AM
CHESTERNUTS
the car runs great rpm's are normal at idle and while driving. No misfire. Though it does seem to eat more fuel more than normal.
Thanks for your help!!
Oct 23, 2009 at 11:21 PM
DOCFIXIT
  • 18,828 POSTS
Clear code see if it resets. I would leave it be will not effect engine operation
Oct 24, 2009 at 12:24 PM
